Meffrig's avatar
Meffrig
Surge guard question/problem ?
Camping World just installed a hard wired Surge Guard (model 34560) on my 2014 Thor Windsport class a motorhome for me. I am visiting a friend and have plugged in to 110 outlet from his garage. I have the proper adapters (50 to 30 to 20 amp) and have power coming into the coach- however the red caution light on the Surge Guard continues to flash. Line 1 and Line 2 light up green as in good to go. I realize I won't be able to run everything in the coach since I am on limited power. Should I be concerned about the flashing caution light? Thanks!
  • I've got a dead President that says it's a reversed phase in the garage receptacle. The surge device will show the fault but everything on 120V will operate.
  • Problem solved- outlet was not grounded properly-life is good. Thanks to all who replied.
  • badboy368 wrote:
    is it possible that you may not be getting a full 110volts? i think that will flash the lights. just a thought :h
    Commercial electrical power in the U.S. hasn't been 110 volts for over 50 years. 120 volts is the standard now.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
