SoundGuy
Sep 02, 2019Explorer
cougar28 wrote:
I have room behind a panel to put the hard wire version. But what if for some reason it goes south? Now your going to have to wire around to restore power.Make it plug and play by putting plugs on each side? If I do that why not just use a portable unit and install behind the panel?
Or just use the portable unit plugging into the power pedestal? Taking the chance of someone walking off with it-water intrusion and just having to deal with every time you set up and leave. What's you thoughts? I'm sure there's more + and - to each one.
Certainly you can solve the potential theft issue by mounting a portable unit inside your rig behind a panel but then you wouldn't see what the display is telling you. Second disadvantage to a portable unit is it's delay is fixed, which in the case of a Progressive unit is 136", while their hard wire unit can be set at 136" or just 15". You could solve the potential theft issue by using a portable unit outside your rig by hanging it under a slide or within a wheel well and use an extension cable to reach the power post. I chose a hard wire version which I located under the sofa and mounted the remote display for it on the wall above the sofa where I could check it at will. For convenience of removal I did add connectors but that does increase the overall cost.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
