CA_Traveler
Sep 02, 2019Explorer III
The inside monitor for the PI unit is a advantage especially in CGs with low voltage during heavy loads like A/Cs running in hot weather. And the prior error code lets you know what happened while you were away.
My 2004 HW50C is in the second RV and no wires were cut to install so easy to remove. It's installed next to the ATS.
There is also a switch on the monitor to turn the unit off. No noise from mine except when it applies power and the relays click.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
