Rover_Bill
Sep 02, 2019Explorer II
The main purpose of any surge protector (portable or hard wired) is to prevent EXCESSIVE voltage from entering the RV. They do that by routing excessive voltage from the hot line back to the ground wire (not neutral line) via metal oxide varistors (MOV) between the two lines.
The MOVs are not damaged if a power surge event is mild, and they will continue to function and protect the RV by bypassing future excessive voltage events. If the surge is extreme (or above the MOV joule rating) the MOVs will be damaged. The MOVs in a hard wired box are replaceable, they are not replaceable in a portable unit. That's why I have mine hard wired.
In either case after the power surge event (assuming the wiring is not physically damaged), power will still be routed to the RV but will not be protected from future surges. It's not like a fuse - once blown then no power until replaced. (At least in theory)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
