ol_Bombero-JC
Sep 04, 2019Explorer
cougar28 wrote:
I have room behind a panel to put the hard wire version. But what if for some reason it goes south? Now your going to have to wire around to restore power.Make it plug and play by putting plugs on each side? If I do that why not just use a portable unit and install behind the panel?
Or just use the portable unit plugging into the power pedestal? Taking the chance of someone walking off with it-water intrusion and just having to deal with every time you set up and leave. What's you thoughts? I'm sure there's more + and - to each one.
I don't expect it to "go south", however -Yes- to your first paragraph. (And - no need to have it outside!)
I have 3 choices with my portable PI - which is always inside - (Out of sight, behind sliding panel). Short section of cable from power panel to 50amp female plug. PI located there. Then.......
1. "Normal" = Connected to the 12V powered cord reel (pull out amt of quality -flexible- cord necessary, push button to retract cord). No "anaconda" to fight!
2. Connect to "original" wiring to the Marinco connection at the rear of the 5th wheel. (If the pedestal is in the rear) Use 15' short 50 amp extension cord to the pedestal. Only needed this once in 13 years.
This also allows me to go back to "original" if I sell the 5th and wish to take the powered cord reel (& cord) with me to the next one.
3. Connect to 30amp cord - to use the gen in pickup bed.
Yes - the portable is "in line" to one (only *one* of the three choices possible) with 50 amp male & female plugs. It can be removed if desired.
:C
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
