Bobbo
Sep 04, 2019Explorer III
ependydad wrote:IAMICHABOD wrote:
Before backing in of pulling in I always check with my home made pedestal checker,cheap but it works.
Saves me the hassel of dragging everything out.
parts list
15 amp to 30 amp Adapter
triplex outlet
Outlet tester
Volt Meter
I had all these around the house,why not use them...
I also use my 50amp to 30amp adapter to check the 50amp side. Sometimes I like them better as they are in better shape.
I like that. I've debated building one for 50amp spots that would check L1 and L2. But never could find my roundtoit.
If you ever do, also add a 240v LED indicator light between the L1 and L2 wires. That will tell you if they cheated and wired both to the same leg, possibly causing a NEUTRAL overload.
240v green LED indicator light
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
