Ron3rd
May 13, 2014Explorer III
When you replace, go with heavy duty shackle links, equalizer, and "Wet Bolts" that you can grease. Replace the bushings in your leaf springs with bronze bushings (if you have the capability) and this will not happen again. Most leaf springs come with plastic bushings and you're are probably gone. The heavy duty parts are thicker and readily available from Dexter and others. Well worth it.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
