Lynnmor
Dec 14, 2019Explorer II
nickthehunter wrote:
They both will do the same thing provided you know how it works and what you are doing - regardless of what the directions say.
As always, folks can't follow simple directions. You loosen the handle so that the sway control can be removed or installed. You tighten the handle when you want the sway control to work. There is no need for extreme tightening, it will work the same regardless of the torque applied. You use the bolt to adjust the amount of control. This device is so simple, but rarely are they adjusted correctly with all the misinformation out there.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
