Lynnmor
Dec 15, 2019Explorer II
wing_zealot wrote:
The only thing that matters is you get the proper amount of pressure on the bar from the friction pad. Doesn't matter how you get there.
So then you can do a complete setup every time you connect if you play with the handle rather that follow the instructions? Tighten the handle and do the adjustment with the bolt, good grief!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
