Need to use all mounting plates when installing sway control on trailer? Have two plates, one with eight holes and the plate with the small ball having four. Can I just use the ball plate? I do have r...
I recommend using the spacer plate. When I first started RV'ing I installed my sway bar mount incorrectly and it caused the bar to crash into itself and the ball mount on the WD hitch during tight turns.
Well, this is what I ended up with.
More importantly than using the plate or not Mount it correctly. This measurement needs to be exact or you can do what I did... I was about 1 inch off IIRC.
thanks!
Jeremiah
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
