Wscott52
Aug 26, 2019Explorer
Sway problems
2015 F250 crew cab short bed 4x4 diesel -8650lbs (front 4900,back 3750) 35”x 12.50 x 18 (12 ply toyo) 2016 keystone impact toyhauler - 10,600lbs loaded, 1550 tongue weight Curt WDH 17501 series w...
librty02 wrote:
Say it ain't so....it's a 3/4 ton it can't have sway issues...lol sorry had to just take a jab at the you can't tow anything unless it's a 1 ton dually crew that's on here....
In all seriousness like said above check your tongue weight loaded with your toys in the back. Take it to the cat scale. A lot of times these toy haulers are tongue heavy empty to compensate for adding weight in the back but some not enough or you just may have to arrange things differently inside. It sounds to me you are under the minimum 10% required tongue weight giving you that sway effect. Also have you messed with the WDH settings at all? A WDH set incorrectly can ruin anyone's towing experience.
