Wscott52ExplorerAug 26, 2019Sway problems2015 F250 crew cab short bed 4x4 diesel -8650lbs (front 4900,back 3750) 35”x 12.50 x 18 (12 ply toyo) 2016 keystone impact toyhauler - 10,600lbs loaded, 1550 tongue weight Curt WDH 17501 series w...Show More
BenKExplorerAug 27, 2019If your shank and ground clearance has room, try dropping the WD hitch head one hole or moreThen go through the setup againThat should end up with your trailer pointed slightly down Make sure there is a min of 12% tongue weight and your TV sits as the manual says and the tires aired up to max sidewall listed PSIAre are the WD bars sized for that tongue weight ?If you haven't, go weigh it, axle by axle. One time with the WD bars tensioned, other not tensioned.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
Related ContentSway ControlSway bar problemsSway Problem / Need HelpSteering & Sway problemAtwood water heater problem
