What tire pressure are you running on the truck. Since you're running a considerably wider tire than stock, you should be running a lower PSI in order to maintain uniform tread contact. Especially if those are M/T tires, because if you run max PSI, they'll be riding on the center tread blocks only, which have zero lateral stability.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
