Wscott52
Aug 26, 2019Explorer
Sway problems
2015 F250 crew cab short bed 4x4 diesel -8650lbs (front 4900,back 3750) 35”x 12.50 x 18 (12 ply toyo) 2016 keystone impact toyhauler - 10,600lbs loaded, 1550 tongue weight Curt WDH 17501 series w...
carringb wrote:
What tire pressure are you running on the truck. Since you're running a considerably wider tire than stock, you should be running a lower PSI in order to maintain uniform tread contact. Especially if those are M/T tires, because if you run max PSI, they'll be riding on the center tread blocks only, which have zero lateral stability.
