Wscott52
Aug 27, 2019Explorer
Sway problems
2015 F250 crew cab short bed 4x4 diesel -8650lbs (front 4900,back 3750) 35”x 12.50 x 18 (12 ply toyo) 2016 keystone impact toyhauler - 10,600lbs loaded, 1550 tongue weight Curt WDH 17501 series w...
twodownzero wrote:
Wow, this one is all over the place. Do not drop your truck's tire pressure to 55, especially on the rear axle. That is dangerous.
It sounds to me like you simply don't have enough tongue weight. Load it heavier. The sway will go away with enough tongue weight. Trying to look for other solutions might work, but adding tongue weight is sure to work.
