t-smith
Jun 20, 2013Explorer
Most 1/2 ton's hitches are rated for 5000lbs, 500lbs tongue weight, and anything higher requires weight distribution. I had towed a 4000lbs TT with my 1/2 ton silverado, and used an Equalizer brand W/D setup, since it incorporates sway control.
Do you NEED W/D for that setup? Need is a strong word, but I think most here would recommend. Sway control IMHO is required.
edit: Remember, you can easily add 1000lbs just from propane, gear, etc into the trailer. So don't forget you will be heavier once loaded.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
