APT
Apr 15, 2014Explorer
A Denali Yukon XL has about 1300 pounds of payload. At 7500 pounds loaded with 900-1000 pounds of TW, you were probably overweight (GVWR, maybe rear axle too) with family onboard. But it should still tow just fine with a properly loaded WDH. If the Denali has air load leveling suspension, then adjusting the WDH usually requires an actual scale.
Spend $14 at a CAT scale before $$10-$50k on a replacement vehicle!
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 21, 2026
