wa8yxm
Oct 08, 2017Explorer III
I too like the idea of a full hook up and use them as much as possible.
For macerator use you can use a tote or a tank. a 55 Gallon drum with a female hose fitting on the vent (small) opening will usually work epically if you have 36 gallon tanks. Outfit the larger opening with the proper cut off valve and I'd use RV type 3" hose at the dump station.
But the totes work well.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
