kedanie
May 20, 2016Explorer II
S Davis wrote:
They will waste more water, unless they have a constant recirculation or heat setting. This setting keeps the heater warm and reduces the amount of time for the heater to start heating the water. Kind of defeats the purpose of the unit. All the tankless heaters take time to sense the water flow, start the ignition cycle and then get the heat exchanger up to temp. could be anywhere from 5 seconds to 20 seconds.
So what is your experience with these units?
Ours fires up in less than 2 seconds with as little flow of .5 gallons per minute.
Our real life propane use is less than with a tank type unit Ike we used to have.
The only advantage tank types have is that they have the ability to run on electricity. With more and more rv parks charging a meter rate for the electricity used, the electric option is a waste compared to the cost of propane.
How much water do you waste when you have to empty the water heater tank after a camping trip?
Check out the real facts for the Precision Temp RV500 on line. Yes, it really does use less propane!
Learn the facts before spreading rumors and non-truths.
Keith
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
