svt440
Aug 09, 2017Explorer
RedRocket204 wrote:
Exactly. I've read of individuals towing open utility trailers (2000lbs) where the tongue weight is too light and they are experiencing frequent sway events. Proper loading on all trailers is key!
A F150 with a tear drop trailer will be a good combo but be vigilant on making sure you are loading it with enough tongue weight and loading balanced, side to side. Do not expect a sway control device to correct a frequent sway problem. Adjust loads to avoid sway first. A sway control device is there for the unique sway event caused by outside forces.
Okay, thank you very much!
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
