Old-Biscuit
Aug 07, 2014Explorer III
1) No electric on site/using an inverter gen......converter DC output should be 13.2V minimum to charge battery
2) Yes you can install screens........just make sure they stay cleaned or you will have issues with fridge cooling/water heater lighting off--staying lit. Air flow is critical to proper operation of RV propane appliances
3) Yes you can leave antenna UP
4) Rig level is critical to proper FRIDGE operation and long life of it's cooling unit. Level trailer for fridge and then dump/rinse waste tanks as needed.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
