Truck has a 'Steer Axle' (That's the Front axle) and a 'Drive Axle' (That would be the Rear Axle)
5th wheel only has Trailer Axle. Forget that 'advertised dry weight'.
When you go to scales you will want to get two complete weigh ins.
1st weigh in...
Drive truck with trailer hooked up onto scales (3 separate platforms)
Truck front axle on front one
Truck rear axle on center one
Trailer axles on rear one
Tell scale operator you are 'private'...they will weigh combo and then you pull off scales.
Go to back of parking lot and drop 5th wheel.
Go back onto scales with truck front axle on forward platform and rear axle on center on.
Tell scale operator.........'private-reweigh'.
They will weigh. Pull off scales.....go park and go inside to get weigh tickets.
One will have the truck Front/Rear Axle weight and the trailer axle weight
The other one will have truck F/R axle weights.
You then have ALL the weight numbers to figure out:
Weight on truck F/R axles hooked up to 5vr
The 5vrs axle weight when hooked up to truck
The truck/trailer combo total weight
Weight on truck F/R axles when NOT hooked to 5vr...plus trucks total weight
The difference in trucks rear axle weight when hooked up to 5vr and when NOT hooked to 5rv is the 5rvs 'Pin Weight'
The 5rvs pin weight plus trailers axle weight will be the 5vrs total weight.
You can then compare the various weight numbers to your trucks axle ratings, tire load ratings, GVWR, trailers GVWR and the trucks GCWR
FAWR.....front axle weight rating
RAWR.....rear axle weight rating
GVWR.....gross vehicle weight rating
GCWR.....gross combined weight rating
Ratings will be on door jam sticker, on trailers VIN Data Plate and on sidewall of tires.
EDIT: Spelling...lack of some letters in words----keyboards fault :S
