rbanuchi's avatar
rbanuchi
The best tow package question
Hello everyone,
I just purchased a 2012 Jeep unlimited and I need to know the best tow package to purchase for my Tiffin Allegro 35QBA. I am going to get the internal bracking package (wired) and I've heard the Blue Ox a is decent tow bar. Can anyone advise about the best tow package and the approximate cost. Any information will be greatly appreciated.
Rob
  • IMO, there is no "best", there is merely what YOU like!
    Get a system that won't bust YOUR budget, and is convenient for YOU to use.
    choose wisely, because you will probably be stuck with it if you don't like it.
    Good luck.
  • The best value (and probably best performing) is the Ready Brake Elite system---------a well built and easy to use towbar combined with a non-electrical brake system.
  • rbanuchi wrote:
    Which system has the ease of releasing pressure at the hitch area to disconnect than having to move your car forward or backward to release pressure ? I apologize for the incorrect terminology but that is the gist of what I meant
    that is why I wanted and used one with levers to release, not slip rings. easier to apply pressure to release when needed.
    bumpy
  • Which system has the ease of releasing pressure at the hitch area to disconnect than having to move your car forward or backward to release pressure ? I apologize for the incorrect terminology but that is the gist of what I meant
  • get a tow bar that stays on the rear of the motorhome and has levers, not slip rings, to release it. I used a blue ox myself, among others.
    bumpy
  • I prefer the Roadmaster as it is 100% USA made. Both Blue OX and Roadmaster are very good alternatives. I believe the connection process with the Roadmaster EZ Base plate is easier.
    I have the Roadmaster Stowmaster tow bar with the EZ baseplate and Roadmaster wiring kit. I do not need to disconnect my toad battery when towing.
    I have the Roadmaster Brakemaster proportional braking system which uses the air brakes on my coach to apply the toad brakes proportionally to the coach brake.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
