K3WE's avatar
K3WE
The connection between the holding tank and the drain...
Through a comedy of errors, I 'tore' the drains off from my holding tanks...THE BEST NEWS is that I was acting as one of those people NOT using the camper restroom for big potty! (I know folks are sometimes over the top about that, but there's no foul for a quick trip and one person to 'be tough' and go to the campground restroom and save the time of dumping)
Anyway- I was amazed to learn that both the black and gray tank connections were not glued, but 'slip in' and 'hose clamp' and I didn't actually TEAR it off, it simply pulled out (more luck).
Quick question- when I put it all back, is there a 'sealing substance' I should put in the joint? Pipe thread putty? Sink drain putty? Some crazy special camper material?
  • There should be a black compression gasket on the pipe. The tighter you tighten the flange nut, the more the washer compresses and holds the inner pipe. Standard plumbing fare.
  • I would think they should be glued. I have never heard of an "approved" plastic system that would be just "pushed together". I wonder if you would not being going through this in the first place if it had been glued at the factory?
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 05, 2025
