dcmac214's avatar
dcmac214
The Longest Sewer Connection You've Made?
Question out of semi-idle curiosity, looking ahead to a summer plan of many many long weekends in the RV.
What's the longest sewer hose connection you've ever had to make?
I'm thinking it'd be a rare site where I'd need more than our 15 & 5 foot hoses connected. ?
  • Came up short once with a 20 Ft hose.
    Now carry 30.
  • If you plan to travel around much and camp at older CGs, 20' could be too short in some cases. The location of your outlet(s) could also be a factor (we have one at rear and another ahead of the axles).
    We've been to some CGs where power & water are at the rear of a site and sewer at the front (and vice versa) and some where 4 sites share a common pedestal which may force you to run your hose under your TT and you'll need more hose. I think 40' is as long as we've needed so far but have 60' at our disposal. I installed a Valterra sewer hose carrier under our TT for and bought 2 high quality hoses for it which are the ones I regularly use. Two of the old hoses are now in the bumper and 2 more are stuffed in a cavity behind the shower "just in case".
    Nowadays there are codes that dictate hookups are to be on the left side and rear of a site and where the inlets are to be on an RV.
  • I’ve needed 40 feet once! I had 2 connectors to use my 20’, and 2 10 footers. The hoses were stretched pretty good. I had an extra 10 footer but not another connector.
  • I've been lucky enough to not need to use my thief yet, but I surely will put some clamps in my tool box. Good idea, thanks. BTW I don't leave the hose connected, I just hook it up long enough to refill the fresh water tank if needed.
