Tiggs's avatar
Tiggs
The road ate my cable ;-(
I'm new to towing and connected the trailer to my tow vehicle and plugged the cable in. Apparently it was long enough to work itself to where it was dragging on the ground, wearing through all the wiring. Of course it was in 5:00 traffic around Washington DC on a Friday afternoon. As a temporary fix, I cut the bad part out of the cable and used 14 gauge wire, connectors and electrical tape to redo the wiring to get back on the road before me and my dogs melted in the heat. Back home now, I will need to make a permanent repair. The cable runs into the underbelly of the trailer and disappears.
Do I have to open up the underbelly of the trailer to find where the end of the cable is attached and replace the entire cable or can I create a waterproof connection at the break and if so, how would be the best way to do it? With a plug to plug connection?
Finally, what is the best way to route the cable so it does not happen again?
Thank you,
Carolyn
  • Use a screen door spring with one end attached at the connector and the other end to your propane tank hold down or some where similar. Keeps cord of the road and still allows for turns.
  • What is a terminal strip?
    Is there any reason why I couldn't tie wrap the cable to the tongue so it doesn't drag in the future or is there a better way?
    Thank you all for taking the time to reply.
    Carolyn
  • The real trick in routing it lies in having it long enough to reach when turned fully both ways, but too short to get near the ground.
  • I had this happen once on my Snowmobile trailer. Some butt connectors and electrical tape and she was back on the road again. That was 13 years ago and its still going strong.
  • I would replace the entire cord it will only be as good as the weakest link when you least expect it there will be an issue such as no lights at night checking just before leaving. Whatever you decide take your time and do the best job you can.
  • Ours came loose and drug the ground while we were getting underway on vacation 3 years ago. We got a new connected and rewired from the break to the 7-pin connector. It's still working.
  • I would install a terminal strip aft of the worn spot, mounted on the frame and replace the cable from there to the 7 pin connector. (TV)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
