valhalla360
Jul 25, 2017Navigator
spoon059 wrote:minnow wrote:
Interesting that GM is reportedly killing off the Volt, the only EV that runs on electricity generated from its internal combustion engine(after the initial battery charge is depleted).
I wonder why car companies haven't capitalized on this idea. Most trains are diesel electric... why aren't there more diesel electric cars that can generate electric power and store it to be used upon demand. Between a diesel engine running and regenerative braking it seems that a lot of power could be made and stored. I'm sure there is a reason, just curious...
Trains don't use diesel-electric due to efficiency. Direct drive would be more efficient. The problem is how do you build a mechanical transmission that can handle over 6,000hp and coordinate up to 6 engines on a single train. The electric motors are effectively acting as a transmission. It also makes coordination between multiple engines easy.
As far as the Volt, GM isn't killing it. It's just not a profitable vehicle. The media is hung up on range but it's not the issue. The issue is cost. EV's (yeah volt is technically a plug in hybrid) cost $10-20k more than they should. A Volt with a 20mile range and a $20k price tag would probably sell and you would likely see 80-90% of all miles done under electric power.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
