txhandgunner wrote:
I've asked this before, but not sure I got my point across.
Why should I buy this for almost $1000...
When this should work just as well for only about $200?
Both are completely safe for 'over-the-road' travel and both would work...
If you still have the Fleetwood Discovery that is in your profile, then towing capacity of the MH is not much of an issue. The question is: what vehicle are you planning to tow behind the motorhome?
An ultra-small car like a mini cooper and smart car does not drive well with the weight of an A-frame tow bar (lower picture) hanging off the front of it. Very small cars need a hitch-based tow bar, not unlike the Ready Brute. On the other hand, a pickup, jeep, or larger SUV can easily drive with an A-frame tow bar on the front of it.
The next question is braking. Although CA, like some other states, is a performance-based state, the problem occurs with being legal everywhere else that you will be towing.
The Ready Brute is an integrated solution. If you go with a tow bar, like the Falcon 2 mentioned above or an A-frame model, you'll need a braking solution. Such a solution can easily cost $800 to $1,500 USD over and above the cost of the tow bar.
In 2011 I had CW install a Roadmaster Falcon 2 tow bar on the MH, Roadmaster base plates on my smart car, and Roadmaster's tail light accessory kit (diodes) on my smart car. In 2011 it cost me $1,938 (OTD). That's 2 grand, and that's not including the cost of supplemental braking.
In the end, to be legal you'll end up spending a chunk of change to flat tow a vehicle. Buying used towing equipment can save you money. Installing the base plates, tail light wiring, and invisibrake/brake buddy/etc yourself can save you money, but if you buy new and have it installed then expect to budget $2,000 to $3,000 to get the job done. With a $200 A-frame tow bar, you might get out the door with spending $1,400 to $1,700. Regardless of the cost, any way you slice it will be a pain in the backside.
