mayo30
Nov 13, 2015Explorer
If it is at or very near the joint you may as well open the whole joint up to repair the leak.The roof wood plywood or what ever likely is the same joint so if you end up replacing wood you will need to get there also.Redo the whole joint.I sure hope you don't find a huge wet area all along the joint.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
