dddire
Oct 14, 2013Explorer
TIme to replace tires... Radial or Bias?
So, two summers and OEM tires are shot, worn out on the inside. Likely due to inadequate pressure (my fault I know)
In searching replacements and looking at the load rating, I'm a little shocked.
Trailer, Jayco x17z, 3200lbs dry, 3500lbs wet max and I know we're at our limits with gear/water etc.
OEM tirs, H188, ST185/80/13D
In looking at replacements on etrailer. The load rating x 2 still is really not that much above the trailer wet weight and some are below...
I know manufactures like to cheap out where they can.. but I can't believe they would put tires that are not up to snuff on a trailer.
Am I looking at this wrong? Two tires.. less tongue weight is my load rating requirement or am I really under on my tires?
If I have to I will go up in size.. but it would be just easier to replace with same tire.. and move one of the worn tires to a spare (still lots of tread left for a spare I'm sure)
Thoughts?
Thoughts?
