Lynnmor wrote:
Since trailer drums or hubs are not balanced from the factory and the tires may be considerably out of balance, how would one guess the proper amount of beads to put in a tire? For example; I have had drums out of balance by 5.5 oz. and tires a similar amount. Depending on the orientation of the tire, I would need something between 1 and 15 ounces to bring it into balance, and then the balancing process would need to start all over again after each stop. Makes no sense to me. I actually balance the entire assembly and leave the gimmicks to others.
According to the Dyna Bead people, "extra" beads just distribute themselves around you tire equally, so only the ones that accumulate in the light spot of the tire actually affect the balance.
