1L243's avatar
1L243
Explorer II
Sep 07, 2021
Tire Failure
I still had the original tires on my 2017 Coleman 300tq Toy hauler.
I was planning on replacing them next year with Good Year Endurance ST Tires.
BUT
On a recent trip to Wyoming I was 200 miles into the days route with 175 to go.
I stopped at a rest area for a short break. This was the first trip with the new TPMS system for the trailer.
As we were getting ready to pull out a tap at the window, a guy towning a toy hauler to Sturgis said I think you got a problem with your trailer tire?
Sure enough...
A 12 inch chunk of rubber was missing. Tire was still holding pressure and temp range was normal. I suspect it just happened as we were pulling into the rest area.
It was 4pm on a Friday and we were 20 miles from a Les Schwab dealer and 175 miles from a Good Year Dealer. Les Schwab won.
My original tires were D rated Constancy tires. Les Schwab's ST tire is a Tow Star E rated tire Yes they have a china stamp on them.
There was no time for procrastinating I needed the tires on.
I have had Les Schwab tires on my truck before and they do all my front end and brake work. They seem to be a stand up company
They got right on it and we were out of there in two hours.
We will just have to see if the ST Tow Stars hold up or not.
I always do a walk around before setting out and saw nothing with the tires but in the future and will be doing a closer inspection before heading out.
  • I am an Anti-Chinese tire person. How much evidence does one need to understand the problem?
  • Les Schwab is a very reputable company. If they stand behind their products then I think you make a good choice. Just make sure they are rated at or above you trailer's weight rating. Also make sure you check the PSI before each trip and keep them aired to the proper number. I am not and Anti-Chinese tire person on origin alone. There are just too many variables to consider.
  • The tire told you it was aging out. A look at the date code would have shown how old they were. Probably made in mid to early 2016 would be my guess. Going up a rating will give you a stronger tire. That tire would have heated up as soon as you got back to highway speed.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
