GizmosMom wrote:
We also have a Class C and at times the ride is rough. We have inflatable shocks. WE set them at 50-60 pounds.
Someone posted an answer to the original poster stating that maybe his tires were inflated too much.
What would cause you to need 60psi in airbags in addition to the spring suspension? Sounds like alot of extra weight, improper use of airbags, or ICBW and the camper is designed to need a significant amount of suspension help even within normal loading.
Assuming it's the first one, then you may need to keep your tires at 80psi if you're packing a bunch of extra weight.
If it's the 2nd one then you need to look at how/why you're deciding to put that much air in a basically new camper.
If it's the last, then I stand corrected.
Regarding tires, you need to have some semblance of what it weighs and then air the tires down accordingly if it's alot lighter than what you're aired up for.
