rogerckExplorerMar 11, 2017Tire InflationI recently replaced the tires on my travel trailer that were four years old and rated at 65 psi maximum. The new tires are rated at 80 lb psi as are the alloy wheels on the trailer. I'd like to incr...Show More
Old-BiscuitExplorer IIIMar 11, 2017Run them at 80#........After several long trips check tire thread wear.IF more wear in center thread vs inside/outside then 80# is over-inflated for load on tiresOR......go weigh trailer camp ready and get an idea of axle weight and then check tire load chart. 80# might be OK or too much based on weight.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 06, 2026
Related ContentTire Load/Inflation CalculationTire inflationBest tire inflator for dually tiresTire inflationTire inflations
