Dutch_12078 wrote:
JimK-NY wrote:
My TPMS system is dead accurate, but....
the signals from the sensors are sent periodically so the system is not useful for adding or dropping pressure.
Exactly, and the reason the flow-thru sensors are not well suited for making pressure adjustments.
The whole purpose with the flow-thru sensors is to make pressure adjustments. I have heard its a bit of slow process ,but I would imagine for a 5 psi or so adjustment it would not be a big deal. As far as periodically, not sure that would be a deterrent . We are not talking any amount of time involved here, it goes from one tire to another within couple seconds or so., but yes you would have to wait for a few seconds for it to come around to the reading of that tire, but its sure doable. Going back ,and forth from the inflator to the gauge is just about the same I would think. Add air read the monitor seems pretty easy to me.
The big reason I didn't go with the flow-thru were the size of them, they are bulky, and stick out a bit more, and the fact they are supposedly pretty slow getting air thru them . I find taking off the non flow-thru sensor is not that much different then removing the valve cap.
