SHRED's avatar
SHRED
Tire Pressure Monitoring Systems
I need a tire pressure monitoring system for my Honda CRV tow vehicle.
I have a 27 foot class c Lazy Daze motorhome that has a system already.
Is there any decent 4 sensor systems under $200 that have the distance range to work?
Thanks
  • SHRED wrote:
    Beverley&Ken wrote:
    What type of system does your LazyDays have? If it is TST, they have a kit with the four sensors and a REPEATER to add on there system. If not TST they also have a 4 sensor kit with repeater and Monitor.
    Most systems are not interchangeable with other manufacturers.
    Ken
    It's the built in FORD E-450 system.
    Is the built-in just the idiot light version? If so, get a TST with enough sensors for all your tires and roll with that. Depending on your pressures that dashboard warning light might be set for way lower than what you should run your tires at for the rig you drive. That way you can monitor temperature too.
  • Just bought a TST-507 on etrailer.com.
    Thanks for the help.
  • I wouldn't want to cheap out on a tpms. The potential damage is way too high even with a toad.
  • I don’t know of any good TPMS system that would be $200.
    I would go with a TST507. It comes with a repeater that will be needed.
    Ken
  • What type of system does your LazyDays have? If it is TST, they have a kit with the four sensors and a REPEATER to add on there system. If not TST they also have a 4 sensor kit with repeater and Monitor.
    Ken
