1L243's avatar
1L243
Explorer II
Oct 23, 2020
Tire Pressure
What's the consensus on Max tire pressure when towing 10K. Generally I run max tire pressure as rated on the tire for both the trailer and tow vehicle, with the exception of the front tires on the tow vehicle I run about 5 lbs under max tire rated pressure because I think the front runs a little light when towing.
  • It depends on the tire installed, and the tires on truck, are usually not the same type as trailer. Most RV trailer tires are ST, and just adequate when oem installed. These I run at max pressure, no matter the load. With the truck tires, it is more important to go with the psi, according to the load. My door sticker shows 75 front 80 rear, which I use when towing heavy. When unloaded, I keep the front near the 75 psi, but lower the rear to 65-70 psi.
    Some people way over tire their RV trailer tires, then reduce the air to suit the load. Usually going from oem D-rated 65 psi, to an E-rated tire is not a problem. I would still run the Es at full 80 psi to take advantage of the extra capacity, and keep them running cooler. replacing a D with a G makes no sense, and no, you wouldn't want to run them at 110 psi
    Jerry
  • So, if they add an additional camp chair or another flat of water bottles, do they weigh the trailer and inflate accordingly? Why make it so difficult? Just inflate to max cold recommendation and be done.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
