spoon059
Dec 13, 2018Explorer III
Why do some people feel the need to over engineer things? Your tire pressure tables are COLD pressures. Cold is defined as tire at rest, not having recently been driven. Whether cold is 0 degrees or 100 degrees, cold is cold.
Before you start your day, check your COLD tire pressure. Set your tire pressure to the recommended PSI. Drive. If you feel the need to check pressures during the day, simply ensure that the PSI hasn't dropped from your initial COLD pressure.
Its tire pressure people... some things are meant to be simple.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
