Grit_dog
Dec 14, 2018Trailblazer
Aside from different loads or seasons (for traction, not temperature per se), tire pressure is set it and forget it.
The one guy who’s pressure went up 15+ psi was partly due to ambient change and part due to tire heat from driving.
Only time I could see adjusting pressure based on temp is if you Dropped 80-100deg ambient and were at your load limits. Then you might want to add 10psi
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
