Golden_HVAC
Aug 15, 2014Explorer
Hi,
It seems like you have a adequate pressure. It might be a little to high, but better to error on the higher side of things. I would try 90 rear and 75 front, it might ride a bit better. There is only about 2,500 pounds on each of the front tires. Rear tires are well under 4,000 pounds, so 90 should be fine.
Fred.
PS: I hope that you already installed a coolant filter. Napa part# FIL 4070 and a kit to install it is FIL 4019. You can do the job yourself in about 2 hours with plenty of time off for coffee breaks.
Fred.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
