Bedlam
Aug 15, 2014Moderator
06Fargo wrote:
Load and inflation tables
your tire size is on page 45.
With a SRW pickup & 2900 pin your tire loading should be just off the low end of the load and inflation table scale.
X2
My truck is about 4500 lbs up front and 2750 lbs on the rear when unloaded to give you a reference. If you can get yourself on the scales loaded,the inflation tables will give you optimum pressures for your load. Keep at least 70 psi in the tires when unloaded to make sure the beads stay seated.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
