peaeye1
Apr 23, 2016Explorer
Tire PSI
on my 2016 Ford F350 superduty dually 4x4 with Goodyear LT 245/75R/17E tires. The Door sticker says 75 front 65 rear cold. Tires say 80 PSI cold. Pardon my ignorance, but which one do I go b...
lbrjet wrote:
Your rears are rated at 2535 per tire in a dual application at 65 psi. Your fronts are rated for 3020 per tire at 75 psi. Both psi's exceed your axle ratings. Ford's recommended tire pressures always assume a maximum load.
