good morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
The sticker on your door reflects the inflation for max. GWR of your truck. That is the info I use to inflate my tires. There is no use going higher unless you are overloading the truck.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
