jimcatinmi
Aug 14, 2020Explorer
tire psi
good morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
12th Man Fan wrote:
The sticker on your door reflects the inflation for max. GWR of your truck. That is the info I use to inflate my tires. There is no use going higher unless you are overloading the truck.
