good morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
Wow, if that FW is hooked up to your F150 and using a heavy Superglide slider, you will need the max tire pressure on the sidewall! What is your RAWR/tire max rating?
That is a nice looking rig, but certainly at truck's limit.
I would add a few lbs to front tires also, even though most all FW weight is carried by the rear.
Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
