jimcatinmiExplorerAug 14, 2020tire psigood morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
Old-BiscuitExplorer IIIAug 14, 202010,735# GVWR on that trailerDRY weight is 7855# with a DRY pin percentage of 20%20% Wet pin......2150# pin weight31'10" length12'1" heightLoad Assist Shocks do NOT add weight carrying capacity...they just help level out and overloaded suspensionToo much trailer/too little of truckHit the SCALES and find out how much you are exceeding trucks ratings.....especially RAWR/Tire MAX Load Ratings
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
