good morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
Since we’re off topic already.... Yes that’s a lot of trailer for a 1/2 ton but a 2100lb pin weight plus hitch will not tank a HD 1/2 ton. But you’ll be right at or a bit over the 4500lb rating of the 9.75 axle....if that weight is accurate.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
