vesh1717
Apr 20, 2014Explorer
Tire question
Hi all.. I need some help. I think have I researched sufficiently, however, before I make a purchase I like to be sure to get some trusted advice.. which is where all of you come in. The situat...
JIMNLIN wrote:vesh1717 wrote:
Yes they are 15s sorry
Now that opens up a whole different range of 15" LT and the all position tires for you.
Replacing ST205/75-15 C with a LT
Depending on room in the wheel well and proper wheel pressure/wheel width requirements the Goodyear Wrangler HT in a LT235/75-15 C (50 psi) at 1980 lb capacity. Most LT tire makers carry this size.
And a Wrangler HT in a LT215/75-15 D (65 psi) at 2090 lbs capacity.
Maxxis LT U-168 are a commercial grade tire with several 15" sizes and have became popular with all types of trailer owners.
Vanco 2 from Continental another popular tire for trailer users has several 15" sizes and load capacities.
I see the Yokohama RY215 in a 700R 15 D at 2040 lbs capacity is popular on some of the other RV websites.
Do your home work on the numbers for top and side clearance issues in your wheel wells. I get by with 2 3/4" at the top and 3/8" on the tires side.
Your trailer with a single axle won't have tire side scrub issues so side clearances can be closer.
