I often see experts on here saying that if you have one flat you should change all four because of the "overloading" that occurs on the other three. I am putting on new brakes, how do I jack it up so...
?? Confusing question, but if you're concerned that the other tires will be overloaded and thus damaged, in a static situation while lifting one wheel (to change brakes), they wont. Even if you were loading the other tires more, it wouldn't matter, but you're not loading the other tires more, you're just letting the jack do the work of the tire that's off.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
