fla-gypsy wrote:
A properly maintained good quality ST tire will last around 5+ years and my last set lasted 6+ years.
You need to go back to OP original post and read it! This is a 14K large trailer! ST235/80R16E tires fail regularly in this application.
Someone with a small light bumper pull talking about ST tire reliability in this situation is apples and oranges. Most are lucky to make it to 3 years.
The problem becomes, what is it 3 or 5 years. How do you know when the tire is ready to go other than luck! You see a problem in the morning inspection, and you are lucky. You see no problem in the morning inspection and 10-100 miles down the road your luck runs out.
It is like playing Russian Roulette with ST tires on large trailers.
Installing a good quality poly carcass LT tire if it meets the requirement ups one's odds quite a bit. Installing a steel ply carcass tire GREATLY improves ones odds. Find a failure report anywhere of a Michelin XPS RIB or Bridgestone Duravis R250 that has failed on a 5th wheel trailer!
Both of these tires are good to 6-8 years and will most likely show hair line cracks in the sidewalls somewhere in the 6-10 year time frame, giving one the notice to replace them. Or just pick a year 6, 7, or 8, and sale them on CL like I did to someone that wants them for an utility trailer or old beater truck.
The other two big pluses are very sable towing and very low rolling resistance for improved mileage.
Chris
